[gdal-dev] Reading JPEG2000 file related to drivers
Yves Jacolin yjacolin at free.fr
Tue Oct 13 01:56:42 PDT 2015
Hello,
Sorry for the long mail. I test jpg2 reading with GDAL for a small piece of
file (12M).
# first test :
$ gdalinfo --version
GDAL 1.10.1, released 2013/08/26
$ gdalinfo file.jp2
Driver: JPEG2000/JPEG-2000 part 1 (ISO/IEC 15444-1)
Files: UnKiloDeJP2000-Ratio25-Pixel-10cm.jp2
       UnKiloDeJP2000-Ratio25-Pixel-10cm.j2w
Size is 10000, 10000
Coordinate System is:
LOCAL_CS["This file was created with the ECW JPEG 2000 SDK build 3.3.0.160
copyright 1998-2005 by ER Mapper.  This GeoJP2 header was translated from the
following ER Mapper style registration information:
        fOriginX:                       1840000.000000
        fOriginY:                       5178000.000000
        fCellIncrementX:                0.100000
        fCellIncrementY",
    UNIT["unknown",1]]
Origin = (1840000.000000000000000,5178000.000000000000000)
Pixel Size = (0.100000000000000,-0.100000000000000)
Corner Coordinates:
Upper Left  ( 1840000.000, 5178000.000)
Lower Left  ( 1840000.000, 5177000.000)
Upper Right ( 1841000.000, 5178000.000)
Lower Right ( 1841000.000, 5177000.000)
Center      ( 1840500.000, 5177500.000)
[Here it hangs and Swap then crash]
ok, let's add 4 Go of RAM (*2 from the first test)) : I get 8 Go RAM full +
~3.5 swap but I get now all the metadata.
# second test
GDAL 2.1.0dev, released 2015/99/99
$ gdalinfo file.jp2
Driver: JP2ECW/ERDAS JPEG2000 (SDK 5.2)
Files:
/home/yjacolin/Documents/Projets/grandlyon_geosupport/01_working_papers/migration_jessie/Ortho_jpg2/UnKiloDeJP2000-
        fCellIncrementY",
    UNIT["unknown",1]]
Metadata:
  ALL_COMMENTS=ECW JPEG 2000 SDK v3.3.0.160
  COLORSPACE=RGB
  COMPRESSION_RATE_TARGET=33
Corner Coordinates:
Band 1 Block=256x256 Type=Byte, ColorInterp=Red
  Description = Red
  Overviews: 5000x5000, 2500x2500, 1250x1250, 625x625, 312x312, 156x156
  Mask Flags: PER_DATASET ALPHA
  Overviews of mask band: 5000x5000, 2500x2500, 1250x1250, 625x625, 312x312,
156x156
Band 2 Block=256x256 Type=Byte, ColorInterp=Green
  Description = Green
156x156
Band 3 Block=256x256 Type=Byte, ColorInterp=Blue
  Description = Blue
156x156
Band 4 Block=256x256 Type=Byte, ColorInterp=Alpha
  Description = AllOpacity
No hang, no swap, no ram used
# Questions :)
* is it possible to choose the driver used by gdal? For instance, in my second
test, my gdal install have two driver; ECW SDK and OpenJpeg. Currently, I am
building several gdal instance to test each driver :/
* the difference between the two test, is it a problem from the driver used of
from gdal release?
Thanks,
Y.
