[gdal-dev] New OGR driver for DB2 Spatial support
David Adler
dadler at adtechgeospatial.com
Mon Oct 26 14:35:48 PDT 2015
I'm getting closer after installing the MS compiler for Python and
running "python setup.py build" successfully but still get a failure.
Does the usual GDAL Python user need to go through all this? I see lots
of information and tutorials about using the GDAL Python API but haven't
found much about setting up the environment in order to get started.
*E:\dwacode\gdal\gdalautotest-2.0.1>python run_all.py
File "run_all.py", line 37, in <module>
import gdaltest
File "pymod\gdaltest.py", line 36, in <module>
from osgeo import gdal
File
"e:\dwacode\gdal\swig\python\build\lib.win32-2.7\osgeo\__init__.py", line
21, in <module>
_gdal = swig_import_helper()
File
17, in swig_import_helper
_mod = imp.load_module('_gdal', fp, pathname, description)
ImportError: DLL load failed: The specified module could not be found.
E:\dwacode\gdal\gdalautotest-2.0.1>dir %pythonpath%
Volume in drive E is EDrive
Volume Serial Number is 17F6-8B91
Directory of e:\dwacode\gdal\swig\python\build\lib.win32-2.7
10/26/2015 05:24 PM <DIR> .
10/26/2015 05:24 PM <DIR> ..
06/12/2015 03:27 PM 133 gdal.py
06/12/2015 03:27 PM 148 gdalconst.py
06/12/2015 03:27 PM 130 ogr.py
10/26/2015 05:28 PM <DIR> osgeo
06/12/2015 03:27 PM 130 osr.py
4 File(s) 541 bytes
3 Dir(s) 50,715,795,456 bytes free
Directory of e:\dwacode\gdal\swig\python\build\lib.win32-2.7\osgeo
10/26/2015 05:28 PM <DIR> .
10/26/2015 05:28 PM <DIR> ..
06/12/2015 03:27 PM 73,360 gdal.py
06/12/2015 03:27 PM 7,570 gdalconst.py
06/12/2015 03:27 PM 53 gdalnumeric.py
06/12/2015 03:27 PM 18,843 gdal_array.py
06/12/2015 03:27 PM 185,934 ogr.py
06/12/2015 03:27 PM 34,532 osr.py
10/26/2015 05:24 PM 308,736 _gdal.pyd
10/26/2015 05:24 PM 24,064 _gdalconst.pyd
10/26/2015 05:25 PM 394,752 _ogr.pyd
10/26/2015 05:24 PM 176,640 _osr.pyd
06/12/2015 03:27 PM 778 __init__.py
10/26/2015 05:28 PM 931 __init__.pyc
12 File(s) 1,226,193 bytes
2 Dir(s) 50,715,795,456 bytes free
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20151026/5c1cca7f/attachment.html>
