[gdal-dev] New OGR driver for DB2 Spatial support
Even Rouault
even.rouault at spatialys.com
Mon Oct 26 12:54:15 PDT 2015
Le lundi 26 octobre 2015 20:32:12, David Adler a écrit :
> Thank you for the quick response.
> I've not used Python before so I'm stumbling getting the environment to
> work. Python 2.7 is installed and I am running from the autotest
> directory. It isn't obvious to me how the PYTHONPATH variable is
> supposed to be set, but I pointed it to the python directory in the gdal
> installation.
> run_all.py is failing with the following:
> *E:\dwacode\gdal\gdalautotest-2.0.1>set
> PYTHONPATH=e:\dwacode\gdal\swig\python
Should rather be PYTHONPATH=e:\dwacode\gdal\swig\python\build\lib-XXXXXXX
(replace XXXX by actual name)
This assumes you have built the bindings with "python setup.py build" in the
e:\dwacode\gdal\swig\python directory
> E:\dwacode\gdal\gdalautotest-2.0.1>python run_all.py -l
> Traceback (most recent call last):
> File "run_all.py", line 37, in <module>
> import gdaltest
> File "pymod\gdaltest.py", line 36, in <module>
> from osgeo import gdal
> File "e:\dwacode\gdal\swig\python\osgeo\__init__.py", line 21, in
> <module>
> _gdal = swig_import_helper()
> File "e:\dwacode\gdal\swig\python\osgeo\__init__.py", line 13, in
> swig_import_
> helper
> import _gdal
> ImportError: No module named _gdal*
> On 10/26/2015 2:12 PM, Even Rouault wrote:
> > Le lundi 26 octobre 2015 18:48:47, David Adler a écrit :
> >> I am close to finished with this driver which was delayed significantly
> >> getting access to a DB2 for z/OS test environment to verify that it
> >> works across IBM DB2 platforms.
> >> What is the proper way to handle authorship in the source code? The DB2
> >> driver is based on the MS SQL driver with significant changes to support
> >> the DB2 environment. Current prologues have information like:
> >> * * Author: Tamas Szekeres, szekerest at gmail.com
> >> ** **** * Copyright (c) 2010, Tamas Szekeres
> >> * Copyright (c) 2010-2012, Even Rouault <even dot rouault at
> >> mines-paris dot org>*
> > Put yourself as author, add yourself (or your company depending on in
> > which context you contribute this) in copyright and retain copyright
> > attributions of portions of code you derive from. Which can be hard to
> > determine in practice. So I'd say retain Tamas ones and you can probably
> > remove mine, which must be anectodical in the case of the MSSQL driver.
> >> I've mostly been testing using the apps test_ogrsf, ogr2ogr and ogrinfo.
> >> Is there any documentation on the autotest system?
> > Well, itself is assumed to be self documented ;-) look at a few existing
> > scripts close to what you want to do and do the same...
> >> It was interesting to
> >> find that there was a 2003 DB2 test driver for DB2 V7
> > You mean the ogr/ogr_db2_hack.py file ? I'm not sure if/which was the
> > corresponding driver. Perhaps the generic OBDC one.
> >> - we are now at
> >> V10.5.
> >> Regards,
> >> David
> This email has been checked for viruses by Avast antivirus software.
> https://www.avast.com/antivirus
http://www.spatialys.com
