[gdal-dev] Gdaltransform hangs sometimes after being idle
Jukka Rahkonen jukka.rahkonen at maanmittauslaitos.fi
Sat Sep 5 10:47:35 PDT 2015
Even Rouault <even.rouault <at> spatialys.com> writes:
> Le samedi 05 septembre 2015 17:39:52, Jukka Rahkonen a écrit :
> > Hi,
> > If I run gdaltransform on Windows and keep it idle for some time the whole
> > command window freezes sometimes so that it does not accept any input,
> > including Ctrl-C for closing the program. I have known the behavior for
> > long and just closed the process from task manager. However, now I saw a
> > new message on my screen which I have not noticed before.
> > CPLMutexHolder: Failed to acquire mutex!
> > Unfortunately I can't reprodoce the freeze in a reliable way.
> Jukka,
> This sounds rather strange. Most mutex locking attempts in GDAL have a
timeout
> of 1000 seconds, so that might explain the "after some time". However I fail
> to see how waiting for input and mutex relate together. Or there would be a
> mutex that wouldn't be released. What is your gdaltransform command line ?
Actually I have the freeze on my computer right now. I did this:
gdaltransform -s_srs epsg:4326 -t_srs epsg:3067
30 65
641428.429705435 7211811.30748109 0
31 70
652590.036387019 7770880.82231984 0
Then I tried to close the program with Ctrl-C but it did not close. Now it
does not take any input at all. It may well be that my issue is exactly that
I can't close gdaltransform with Ctrl-C after idle time and perhaps I have
seen the same with cs2cs.
In an earlier test I got this print on my screen, I don't know if it is
related or not:
HDF5-DIAG: Error detected in HDF5 (1.8.14) thread 0:
  #000: ..\..\src\H5I.c line 1138 in H5Iget_type(): library initialization faile
d
    major: Function entry/exit
    minor: Unable to initialize object
  #001: ..\..\src\H5.c line 183 in H5_init_library(): unable to initialize prope
rty list interface
  #002: ..\..\src\H5Pint.c line 405 in H5P_init(): interface initialization fail
ed
  #003: ..\..\src\H5Pint.c line 468 in H5P_init_interface(): can't register prop
erties
    major: Property lists
    minor: Unable to register new atom
  #004: ..\..\src\H5Pfapl.c line 241 in H5P_facc_reg_prop(): can't insert proper
ty into class
    minor: Unable to insert object
  #005: ..\..\src\H5Pint.c line 2002 in H5P_register_real(): Can't create proper
ty
    minor: Unable to create file
  #006: ..\..\src\H5Pint.c line 1072 in H5P_create_prop(): memory allocation fai
led
    major: Resource unavailable
    minor: No space available for allocation
  #007: ..\..\src\H5FD.c line 386 in H5FD_register(): memory allocation failed f
or file driver class struct
FATAL: CPLGetTLSList() failed to allocate TLS list!
-Jukka-
