[gdal-dev] projection error
Jukka Rahkonen
jukka.rahkonen at maanmittauslaitos.fi
Tue Sep 8 04:51:27 PDT 2015
Hema Yeedunuri <hema.yeedunuri <at> amigooptima.in> writes:
> hi all,
> i have a geotiff file .i have wrapper classes for gdal for reading and
writing.gdal version is 1.11 and proj is 4.2 .whe i try to load a file it is
giving following error.i am using ubuntu 12.04.
> ERROR 1: Only OGC WKT Projections supported for writing to GeoTIFF.
I fear that with that information nobody can solve your issue. The error
suggests that you are trying to write into GeoTIFF something that is not OGC
WKT Projection. You must tell us what you try to write into GeoTIFF, even
better if you attach the failing code as well.
You say that you try to load a file and the error says that you try to write
something invalid into a file so perhaps your code does not do what you
believe it does.
For self-help I believe this is useful http://www.gdal.org/osr_tutorial.html
and probably this also
http://stackoverflow.com/questions/13158795/create-a-geotiff-from-an-existing-bitmap-in-c-sharp-with-gdal.
-Jukka Rahkonen-
