[gdal-dev] Update of config files for gdal
Gawade P
gawade.oefp at gmail.com
Tue Sep 8 21:01:26 PDT 2015
Thanks, Even and apologies for the delayed response.
I believe that the recommendation is to update it to the git HEAD version.
https://www.gnu.org/software/gettext/manual/html_node/config_002eguess.html
Based on the above information, the latest ones reside here:
http://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.guess;hb=HEAD
http://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.sub;hb=HEAD
Ticket for the request:
https://trac.osgeo.org/gdal/ticket/6101#ticket
Please let me know if there is any other information required from my
side or anything I can do to help with this.
Thanks!
On Fri, Sep 4, 2015 at 5:13 PM, Even Rouault <even.rouault at spatialys.com> wrote:
> Le vendredi 04 septembre 2015 12:43:21, Gawade P a écrit :
>> Hi,
>> Can we consider updating the config.guess and config.sub files in the
>> source to the latest available version?
>> The current one does not have support for newer platforms like ppc64le.
>> Please let me know your thoughts.
> That would probably be a good idea. I'm not sure what is the nominal source for those files.
> Last time they have been refreshed was with r19558 5 years ago
> "Update to autoconf 2.64 and libtool 2.2.6; refresh configure",
> but I'm not sure if the change was really due to the update of autoconf/libtool, or they came from my system.
> I see that for the Android builds (https://github.com/rouault/gdal_coverage/blob/trunk_android/.travis.yml),
> we get them from Savannah, so would be better if they are already up-to-date.
> wget http://git.savannah.gnu.org/cgit/config.git/plain/config.guess -O config.guess
> wget http://git.savannah.gnu.org/cgit/config.git/plain/config.sub -O config.sub
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
