[gdal-dev] Call for discussion on RFC 59 (v2): GDAL/OGR utilities as a library
Even Rouault
even.rouault at spatialys.com
Wed Sep 9 02:38:04 PDT 2015
> In terms of
> unsetting options, will passing NULL to the relevant setter do the trick,
> or do we need to
> re-create the structure in that case?
The setters should behave nicely hopefully (ie deallocate any previously
allocated/duplicated objected, and assign NULL ). If for some reason that is
not possible (not sure why it wouldn't), then it should be documented in the
setter.
http://www.spatialys.com
