[gdal-dev] Call for discussion on RFC 59 (v2): GDAL/OGR utilities as a library
Homme Zwaagstra hrz at geodata.soton.ac.uk
Wed Sep 9 02:58:51 PDT 2015
On 09/09/15 10:38, Even Rouault wrote:
>> In terms of
>> unsetting options, will passing NULL to the relevant setter do the trick,
>> or do we need to
>> re-create the structure in that case?
> The setters should behave nicely hopefully (ie deallocate any previously
> allocated/duplicated objected, and assign NULL ). If for some reason that is
> not possible (not sure why it wouldn't), then it should be documented in the
> setter.
Perfect, thanks.
Homme.
