On Thu, 17 Sep 2015 11:19:47 AM Even Rouault wrote: > Basically if you download > https://github.com/rouault/pdfium/blob/build/build- lin.sh , run it, it > will install pdfium to $HOME/pdfium/install So there is no shared library or configuration data need here? Brad
