[gdal-dev] Handling pdfium build / integration
Even Rouault even.rouault at spatialys.com
Thu Sep 17 06:03:42 PDT 2015
Le jeudi 17 septembre 2015 14:03:06, Brad Hards a écrit :
> On Thu, 17 Sep 2015 11:19:47 AM Even Rouault wrote:
> > Basically if you download
> > https://github.com/rouault/pdfium/blob/build/build- lin.sh , run it, it
> > will install pdfium to $HOME/pdfium/install
> So there is no shared library or configuration data need here?
No, plain static linking. It might be possible to make a shared library from
pdfium, but I haven't explored that.
> Brad
http://www.spatialys.com
