[gdal-dev] Generating 200x200 tiles
Brad Hards
bradh at frogmouth.net
Thu Sep 17 16:36:49 PDT 2015
On Thu, 17 Sep 2015 06:03:15 PM Alistair Young wrote:
> I've been using gdal2tiles to generate zoom levels and tiles and it's
> working fine but unfortunately the tiles are 256x256 and don't work with
> the UK Ordnance Survey mapping SDK, which requires 200x200 tiles. Is there
> a way to generate these 200x200 tiles? I can generate them using
> gdal_retile but it can't generate the zoom levels.
I'd suggest just hacking the python script. Make a copy, and edit the
__init__() function to change the tileSize member init to be 200 vs 256.
Worth a quick try at least.
Brad
