[gdal-dev] Generating 200x200 tiles
Alistair Young
alistair.young at uhi.ac.uk
Sat Sep 19 00:14:15 PDT 2015
Thanks for that. I tried ctb but just got "Could not get transformation
information from source dataset². Chaning gdal2tiles to output 200x200
worked ok but the SDK failed to display the tiles. I just have a 4000x4000
tif with no geo referencing information so I can only generate raster
profile tiles.
Alistair
mov eax,1
mov ebx,0
int 80
On 18/09/2015 00:36, "gdal-dev-bounces at lists.osgeo.org on behalf of Brad
Hards" <gdal-dev-bounces at lists.osgeo.org on behalf of bradh at frogmouth.net>
wrote:
>On Thu, 17 Sep 2015 06:03:15 PM Alistair Young wrote:
>> I've been using gdal2tiles to generate zoom levels and tiles and it's
>> working fine but unfortunately the tiles are 256x256 and don't work with
>> the UK Ordnance Survey mapping SDK, which requires 200x200 tiles. Is
>>there
>> a way to generate these 200x200 tiles? I can generate them using
>> gdal_retile but it can't generate the zoom levels.
>I'd suggest just hacking the python script. Make a copy, and edit the
>__init__() function to change the tileSize member init to be 200 vs 256.
>Worth a quick try at least.
>Brad
>_______________________________________________
>gdal-dev mailing list
>gdal-dev at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/gdal-dev
