[gdal-dev] ogr2ogr convert geojson to MapInfo tab
Even Rouault even.rouault at spatialys.com
Fri Sep 18 06:27:29 PDT 2015
Le vendredi 18 septembre 2015 15:08:31, Maxime Demers a écrit :
> Hi Even,
> I just proceeded to test the conversion from geojson to mapInfo tab with
> the latest build. The result is not good.
Maxime,
Which binary did you use ?
If that works, that will report :
PROJCS["WGS 84 / Pseudo-Mercator",
    GEOGCS["unnamed",
        DATUM["WGS_1984",
            SPHEROID["WGS 84 (MAPINFO Datum 157)",6378137.01,298.257223563],
            TOWGS84[0,0,0,0,0,0,0]],
        PRIMEM["Greenwich",0],
        UNIT["degree",0.0174532925199433]],
    PROJECTION["Mercator_1SP"],
    PARAMETER["central_meridian",0],
    PARAMETER["scale_factor",1],
    PARAMETER["false_easting",0],
    PARAMETER["false_northing",0],
    UNIT["Meter",1.0],
    EXTENSION["PROJ4","+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0
+x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +wktext  +no_defs"]]
Even
http://www.spatialys.com
