[gdal-dev] gdalwarp clip ratser using WKT polygon and multi polygon
prpp
pritimoy.podder at deimos-space.com
Mon Sep 21 08:12:30 PDT 2015
I want to clip a raster image using the gdalwarp command. I like to use WKT
polygons and multi polygons as follows:
I know it is possible to clip image using shape file and I also did it using
geometry extracted from the postgis DB.
Any help will be appreciated.
Thanks.
Pritimoy
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdalwarp-clip-ratser-using-WKT-polygon-and-multi-polygon-tp5225293.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
