[gdal-dev] ogr2ogr - geojson to mapInfo - size of .dat become too big
Maxime Demers burton449geo at gmail.com
Tue Sep 22 07:07:56 PDT 2015
I have notice something bad when converting a geojson to mapInfo tab with
ogr2ogr. The .dat which contain the table feature's properties is getting
way too big after conversion.
To test, I have converted a mapInfo tab to geojson using:
ogr2ogr -f "GeoJSON" test.geojson test.tab
and then I converted it back to mapInfo tab using:
ogr2pgr -f "MapInfo File" test2.tab test.geojson
Before convertion, the .dat of the mapInfo file was 8,75 Mo after
conversion it became 105 Mo.
I dont know if the problem is only when converting geojson to mapInfo tab.
What could be the cause of the problem and does a solution exists?
Thank you,
Maxime Demers
Stack Overflow: http://stackoverflow.com/users/1914034/burton449
GIS Overflow: http://gis.stackexchange.com/users/14426/burton449
LastFm: http://www.lastfm.fr/user/burton449
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150922/dc6cbb22/attachment.html>
