[gdal-dev] GetFIDColumn : FID Column for ESRI Shape file
Even Rouault even.rouault at spatialys.com
Wed Sep 30 06:37:27 PDT 2015
Le mercredi 30 septembre 2015 15:32:40, Gane R a écrit :
> Hi,
> Is it that OGRLayer::GetFIDColumn will return empty string for Shapefile I
> have or it will be always empty for all shape files?
Always empty
> If I can see FID Column for a shape file in any other application can you
> name any one of them
They likely use a conventionnal name. But technically there's no field in the
.dbf or the .shp to hold the name of the FID.
Also good to know: the OGR shapefile driver starts its numbering at 0 for the
FID.
> Gane
http://www.spatialys.com
