[gdal-dev] GDAL/OGR 2.1.0 Beta 1 Available
Sean Gillies
sean at mapbox.com
Fri Apr 1 10:44:15 PDT 2016
Excellent, Even. 🎩
I'm add 2.1beta1 to the Rasterio build matrix right now.
On Fri, Apr 1, 2016 at 11:18 AM, Even Rouault <even.rouault at spatialys.com>
wrote:
> Hi,
> Despite the date, I do have prepared the GDAL/OGR 2.1.0 Beta1 release. It
> will potentially be followed by a second beta in the second half of this
> month, or directly by a RC1 if things go well. The source is available at:
> http://download.osgeo.org/gdal/2.1.0beta1/gdal-2.1.0beta1.tar.xz
> http://download.osgeo.org/gdal/2.1.0beta1/gdal-2.1.0beta1.tar.gz
> http://download.osgeo.org/gdal/2.1.0beta1/gdal210beta1.zip
> A snapshot of the Python autotest suite can be downloaded from:
> http://download.osgeo.org/gdal/2.1.0beta1/gdalautotest-2.1.0beta1.tar.gz
> http://download.osgeo.org/gdal/2.1.0beta1/gdalautotest-2.1.0beta1.zip
> The preliminary NEWS is available at :
> http://svn.osgeo.org/gdal/trunk/gdal/NEWS
> New bugs found should be filed in Trac normally.
> http://trac.osgeo.org/gdal
> GDAL developers and users are encouraged to treat the coming weeks
> as the prime time for bug finding and fixing.
> GDAL committers should be even more careful than usually about what they
> commit in this period before the actual release. I haven't yet created a
> 2.1
> branch, so anything that is committed into trunk for now will be in final
> 2.1.
> If that blocks development for anyone, we can easily create the 2.1 branch
> when needed.
> For Ari mostly:
> Regarding Perl bindings, the usual mkgdaldist.sh script had an issue when
> generated the bindings file, because swig/perl/include/perl/typemaps_perl.i
> requires port/cpl_config.h to be generated. But the script runs on a svn
> export, so without any generated file. So for now I commented out the part
> that
> tries to generate the Perl bindings, so as to go on.
> The likely consequence is that ./configure --with-perl && make fails with
> "Use of uninitialized value $ARGV{"--gdal-source-tree"} in string eq at
> Makefile.PL line 61.
> GDAL Perl modules not found, perhaps you need to run make generate? at
> Makefile.PL line 77.""
> But manual cd swig/perl && make works
> Ari, would you mind looking at that (by trying mkgdaldist.sh) ?
> Best regards,
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Sean Gillies
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160401/7c5e5cea/attachment.html>
