[gdal-dev] GDAL 2.1 Beta and GRASS 7.0.4
Even Rouault even.rouault at spatialys.com
Mon Apr 4 07:10:32 PDT 2016
Le lundi 04 avril 2016 15:45:48, Blumentrath, Stefan a écrit :
> Hi,
> I try to build GDAL 2.1 with GRASS (7.0.4svn) support.
> As far as I can see there is no GRASS-plugin for GDAL 2.x..., so I do: 1)
> build GDAL, 2) build GRASS, 3) rebuild GDAL --with-grass. Unfortunately, I
> get the following error:
Stefan
thanks for the report. I've committed in trunk r33893 a changeset that should
hopefully fix the compilation error, however I don't have a setup to test, so
I'd appreciate your feedback.
So for the final 2.1, we will have to provide an updated snapshot of the gdal-
grass plugin sources.
Even
http://www.spatialys.com
