[gdal-dev] GDAL 2.1 Beta and GRASS 7.0.4
Blumentrath, Stefan
Stefan.Blumentrath at nina.no
Mon Apr 4 07:40:36 PDT 2016
Hi Even,
Many thanks for the quick fix!
Works fine now!
BTW, are there any plans for a GDAL-GRASS-plugin in GDAL 2.x?
Cheers
Stefan
-----Original Message-----
From: Even Rouault [mailto:even.rouault at spatialys.com]
Sent: 4. april 2016 16:11
To: gdal-dev at lists.osgeo.org
Cc: Blumentrath, Stefan <Stefan.Blumentrath at nina.no>
Subject: Re: [gdal-dev] GDAL 2.1 Beta and GRASS 7.0.4
Le lundi 04 avril 2016 15:45:48, Blumentrath, Stefan a écrit :
> Hi,
> I try to build GDAL 2.1 with GRASS (7.0.4svn) support.
> As far as I can see there is no GRASS-plugin for GDAL 2.x..., so I do:
> 1) build GDAL, 2) build GRASS, 3) rebuild GDAL --with-grass.
> Unfortunately, I get the following error:
Stefan
thanks for the report. I've committed in trunk r33893 a changeset that should hopefully fix the compilation error, however I don't have a setup to test, so I'd appreciate your feedback.
So for the final 2.1, we will have to provide an updated snapshot of the gdal- grass plugin sources.
Even
Spatialys - Geospatial professional services http://www.spatialys.com
