[gdal-dev] GDAL 2.1 Beta and GRASS 7.0.4
Even Rouault even.rouault at spatialys.com
Mon Apr 4 07:48:20 PDT 2016
Le lundi 04 avril 2016 16:40:36, Blumentrath, Stefan a écrit :
> Hi Even,
> Many thanks for the quick fix!
> Works fine now!
> BTW, are there any plans for a GDAL-GRASS-plugin in GDAL 2.x?
There is already the following for GDAL 2.0.X
http://download.osgeo.org/gdal/2.0.0/gdal-grass-2.0.0.tar.gz
And for GDAL 2.1, a new snapshot from trunk with the above fix will be done.
You can already build the plugin snapshot by yourself from the GDAL source
tree :
- cd frmts/grass
- make dist
And this will generate gdal-grass-2.1.0.tar.gz
> Cheers
> Stefan
> -----Original Message-----
> From: Even Rouault [mailto:even.rouault at spatialys.com]
> Sent: 4. april 2016 16:11
> To: gdal-dev at lists.osgeo.org
> Cc: Blumentrath, Stefan <Stefan.Blumentrath at nina.no>
> Subject: Re: [gdal-dev] GDAL 2.1 Beta and GRASS 7.0.4
> Le lundi 04 avril 2016 15:45:48, Blumentrath, Stefan a écrit :
> > Hi,
> > I try to build GDAL 2.1 with GRASS (7.0.4svn) support.
> > As far as I can see there is no GRASS-plugin for GDAL 2.x..., so I do:
> > 1) build GDAL, 2) build GRASS, 3) rebuild GDAL --with-grass.
> > Unfortunately, I get the following error:
> Stefan
> thanks for the report. I've committed in trunk r33893 a changeset that
> should hopefully fix the compilation error, however I don't have a setup
> to test, so I'd appreciate your feedback. So for the final 2.1, we will
> have to provide an updated snapshot of the gdal- grass plugin sources.
> Even
> Spatialys - Geospatial professional services http://www.spatialys.com
