[gdal-dev] ogr2ogr failing on postgis?
Dmitry Baryshnikov
bishop.dev at gmail.com
Sun Apr 10 08:56:47 PDT 2016
Hi Paolo,
It seems to me that your shape spatial reference not present in
spatial_ref_sys and GDAL try to import it into spatial_ref_sys.
Your shape file have such SRS:
PROJCS["Monte_Mario_Italy_zone_1",GEOGCS["GCS_Monte
Mario",DATUM["D_Monte_Mario",SPHEROID["International_1924",6378388,297]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",9],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",1500000],PARAMETER["false_northing",0],UNIT["Meter",1]]
If I execute such SQL: select * from spatial_ref_sys where srtext like
'%Monte_Mario%' I received:
4265;"EPSG";4265;"GEOGCS["Monte
Mario",DATUM["Monte_Mario",SPHEROID["International
1924",6378388,297,AUTHORITY["EPSG","7022"]],TOWGS84[-104.1,-49.1,-9.9,0.971,-2.917,0.714,-11.68],AUTHORITY["EPSG","6265"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745
4806;"EPSG";4806;"GEOGCS["Monte Mario
(Rome)",DATUM["Monte_Mario_Rome",SPHEROID["International
1924",6378388,297,AUTHORITY["EPSG","7022"]],TOWGS84[-104.1,-49.1,-9.9,0.971,-2.917,0.714,-11.68],AUTHORITY["EPSG","6806"]],PRIMEM["Rome",12.45233333333333,AUTHORITY["EPSG","8906"]
3003;"EPSG";3003;"PROJCS["Monte Mario / Italy zone 1",GEOGCS["Monte
3004;"EPSG";3004;"PROJCS["Monte Mario / Italy zone 2",GEOGCS["Monte
26591;"EPSG";26591;"PROJCS["Monte Mario (Rome) / Italy zone 1
(deprecated)",GEOGCS["Monte Mario
26592;"EPSG";26592;"PROJCS["Monte Mario (Rome) / Italy zone 2
I think you need to reproject shape file to EPSG: 3003 or defined it for
shape file.
Best regards,
Dmitry
10.04.2016 18:23, Paolo Cavallini пишет:
> Hi all,
> I have an ogr2ogr command, from shp to pg, that fails because it
> requests write access to spatial_ref_sys. An apparently identical
> command on another file runs smoothly. Any hint?
> Details and data documented here:
> http://hub.qgis.org/issues/14650
> Thanks.
