[gdal-dev] ogr2ogr failing on postgis?
Even Rouault even.rouault at spatialys.com
Sun Apr 10 09:01:54 PDT 2016
Hi Paolo,
> Hi all,
> I have an ogr2ogr command, from shp to pg, that fails because it
> requests write access to spatial_ref_sys. An apparently identical
> command on another file runs smoothly. Any hint?
> Details and data documented here:
> http://hub.qgis.org/issues/14650
Yes, this is expected and a rather common problem with shapefiles. As the
shapefile .prj doesn't contain any explicit EPSG code, the PostGIS driver tries
to find a match in spatial_ref_sys based on an exact match on the WKT, but as
the OGC WKT built from the .prj is different from the one in spatial_ref_sys
(one of the difference is the absence of the AUTHORITY["EPSG","3003"] node of
course !), it must fallback to creating an ad-hoc entry, hence the need for
write access.
Workaround: provide explicit SRS, in that case -a_srs EPSG:3003 (as I can see
in the .qpj)
A more "fuzzy" indentification of SRS could help for that.
Even
http://www.spatialys.com
