[gdal-dev] Problem with gdal_pansharpen tool
Even Rouault
even.rouault at spatialys.com
Fri Apr 22 09:06:20 PDT 2016
Le vendredi 22 avril 2016 17:57:57, Lorenzo Bernardi a écrit :
> I'm using the gdal version provided with the OSGeo4W suite.
> i have performed and updated just yesterday.
> Do you know some solutions?
I presume you use the gdal-dev environement ?
If so, have a look at
https://lists.osgeo.org/pipermail/gdal-dev/2016-April/044074.html
Or as a workaround :
gdal_pansharpen -of VRT panchro.tif multispectral.tif pansharpend_output.vrt
gdal_translate pansharpend_output.vrt pansharpend_output.tif
http://www.spatialys.com
