[gdal-dev] Problem with gdal_pansharpen tool
Even Rouault even.rouault at spatialys.com
Fri Apr 22 09:27:04 PDT 2016
(Please keep the list CC'ed)
> I tryed the solutions: gdal_pansharpen -of VRT panchro.tif
> multispectral.tif pansharpend_output.vrt
> but it does not work.
That's not very informative for people not viewing your screen... Error
message ?
> i'm not sure if i'm using the gdal-dev environment. how can  i verifying
> it?
You have to enable it explicitly with "gdal-dev-env". You can check with
gdalinfo --version
Then redefine PYTHONPATH as explained in the below link
And check that the following also report GDAL 2.1.0
python -c "from osgeo import gdal; print gdal.VersionInfo('')"
> 2016-04-22 18:06 GMT+02:00 Even Rouault <even.rouault at spatialys.com>:
> > Le vendredi 22 avril 2016 17:57:57, Lorenzo Bernardi a écrit :
> > > I'm using the gdal version provided with the OSGeo4W suite.
> > > i have performed and updated just yesterday.
> > > Do you know some solutions?
> > I presume you use the gdal-dev environement ?
> > If so, have a look at
> > https://lists.osgeo.org/pipermail/gdal-dev/2016-April/044074.html
> > Or as a workaround :
> > gdal_pansharpen -of VRT panchro.tif multispectral.tif
> > gdal_translate pansharpend_output.vrt pansharpend_output.tif
> > Spatialys - Geospatial professional services
> > http://www.spatialys.com
