[gdal-dev] GDAL 2.1.0, released 2016/04/25
Francisco José Raga López franka1986 at gmail.com
Wed Aug 17 05:58:24 PDT 2016
HI.
I'm using gdal for java in a personal project,but I have a question.
What version java is need?
I'm using eclipse and If I use jdk 1.7.0 return this error,when debugging.
Native library load failed.
java.lang.UnsatisfiedLinkError: C:\Program Files\GDAL\gdaljni.dll: No
se encontró el proceso especificado
Exception in thread "main" java.lang.UnsatisfiedLinkError:
org.gdal.gdal.gdalJNI.AllRegister()V
at org.gdal.gdal.gdalJNI.AllRegister(Native Method)
at org.gdal.gdal.gdal.AllRegister(gdal.java:493)
But in jdk 1.8 it ok.
gdal 2.1.0 need java 1.8 or higher??
thanks
Analista/Desarrollador GIS Open Source "QGis"
Móvil: (+34) 654275432 | e-Mail: franka1986 at gmail.com | skype: francisco_raga
Github: https://github.com/All4Gis
Linkedin: https://es.linkedin.com/in/franciscojoseragalopez
"La vida real no tiene ningún mapa.."  Ivy Compton Burnett
