[gdal-dev] GDAL 2.1.0, released 2016/04/25
Even Rouault
even.rouault at spatialys.com
Wed Aug 17 06:12:46 PDT 2016
Le mercredi 17 août 2016 14:58:24, Francisco José Raga López a écrit :
> HI.
> I'm using gdal for java in a personal project,but I have a question.
> What version java is need?
1.5 or later
> I'm using eclipse and If I use jdk 1.7.0 return this error,when debugging.
> Native library load failed.
> java.lang.UnsatisfiedLinkError: C:\Program Files\GDAL\gdaljni.dll: No
> se encontró el proceso especificado
> Exception in thread "main" java.lang.UnsatisfiedLinkError:
> org.gdal.gdal.gdalJNI.AllRegister()V
> at org.gdal.gdal.gdalJNI.AllRegister(Native Method)
> at org.gdal.gdal.gdal.AllRegister(gdal.java:493)
> But in jdk 1.8 it ok.
> gdal 2.1.0 need java 1.8 or higher??
No, it is likely an issue with the PATH and/or -Djava.library.path=... not
pointing to gdaljni.dll and/or libgdal20.dll
> thanks
> Analista/Desarrollador GIS Open Source "QGis"
> Móvil: (+34) 654275432 | e-Mail: franka1986 at gmail.com | skype:
> francisco_raga Github: https://github.com/All4Gis
> Linkedin: https://es.linkedin.com/in/franciscojoseragalopez
> "La vida real no tiene ningún mapa.." Ivy Compton Burnett
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
