[gdal-dev] Call for discussion on RFC 64: Triangle, Polyhedral surface and TIN
Michael Sumner
mdsumner at gmail.com
Tue Dec 6 12:31:57 PST 2016
Thanks Even,
Does a TriangulatedSurface consist of separate Triangles, all with each
three vertices stored explicitly? I.e. is there no shared vertex pool that
primitives use via index?
That seems to be what simple features dictates, but it's unclear to me how
applications should work with it. Is vertex de-duplication to be be done at
each conversion, or is there a way to carry those indexes through?
Cheers, Mike
On Wed, Dec 7, 2016, 03:22 Even Rouault <even.rouault at spatialys.com> wrote:
> Hi,
> This is a call to discuss the proposed RFC 64: Triangle, Polyhedral
> surface and TIN
> https://trac.osgeo.org/gdal/wiki/rfc64_triangle_polyhedralsurface_tin
> Summary:
> As of now, the OGRGeometry class (the base class from which all the
> subtypes are derived) is limited to OGRCompoundCurve, OGRCircularString,
> OGRLinearRing, OGRMultiLineString, OGRMultiPoint, OGRMultiPolygon,
> OGRMultiCurve, OGRSimpleCurve, OGRCurvePolygon and OGRPolygon.
> This RFC addresses the addition of the following new geometries in
> OGRGeometry:
> * Triangle - A subset of polygons, the fundamental difference is that it
> is made of 3 nodes only (actually 4, with the last one being the repetition
> of the first one) and ONLY ONE exterior boundary and NO interior polygons.
> * PolyhedralSurface - A 3D figure made exclusively of Polygons.
> * TriangulatedSurface - A subset of PolyhedralSurface; a 3D figure which
> consists exclusively of Triangles.
> I've rebased and extended the work done by Avyav during last GSoc on top
> of current trunk, where it passes our continuous integration tests. I think
> we should consider merging it soon as it can easily rot if kept longer in a
> branch (the refresh from my previous branch dating to end of August was
> rather painful)
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Dr. Michael Sumner
Software and Database Engineer
Australian Antarctic Division
203 Channel Highway
Kingston Tasmania 7050 Australia
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20161206/ce990bf1/attachment.html>
