[gdal-dev] RFC 61: Call for vote on adoption
Ari Jolma
ari.jolma at gmail.com
Fri Feb 5 00:04:00 PST 2016
I'd like to ask the PSC and others to vote on adopting RFC 61: Support
for measured geometries.
The draft RFC is at
https://trac.osgeo.org/gdal/wiki/rfc61_support_for_measured_geometries
and a draft implementation is at
https://github.com/ajolma/GDAL-XYZM
which is tested at
https://travis-ci.org/ajolma/GDAL-XYZM
(the test #34, which passed, was the so far last one after core changes
with unchanged autotests and a rather comprehensive set of WKT tests in
the Perl tests directory)
This is seemingly a small change but it is at the heart of OGR so it has
some important implications. The only backwards incompatibilities that
have appeared so far are with some drivers, for example shapefile, which
can be lessened with, e.g., open options.
Best,
Ari
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160205/f360136b/attachment.html>
