[gdal-dev] Get EPSG code from WKT
Gane R gane.prog at gmail.com
Thu Feb 18 04:09:05 PST 2016
When I try to convert to different projection using the gdalwarp
*without *specifying
the* -s_srs option* it reprojects to a *different location*, for some
raster it projects to a correct location.
But when try to run gdalinfo and I see a lot of EPSG code, when I use the
last AUTHORITY EPSG code as -s_srs option the above mention problem is
solved.
Is it that I have use the last AUTHORITY EPSG code or any thing will help
Expecting your suggestion
Gane
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160218/30844078/attachment.html>
