[gdal-dev] Get EPSG code from WKT
Jukka Rahkonen jukka.rahkonen at maanmittauslaitos.fi
Thu Feb 18 05:48:30 PST 2016
Gane R <gane.prog <at> gmail.com> writes:
> When I try to convert to different projection using the gdalwarp without
specifying the -s_srs option it reprojects to a different location, for some
raster it projects to a correct location.
> But when try to run gdalinfo and I see a lot of EPSG code, when I use the
last AUTHORITY EPSG code as -s_srs option the above mention problem is solved.
> Is it that I have use the last AUTHORITY EPSG code or any thing will help
> Expecting your suggestion
Expecting some sample data that could be used for reproducing the problem.
-Jukka Rahkonen-
