[gdal-dev] gdalwarp and gdaladdo in multi-threaded mode
Neumann, Andreas
a.neumann at carto.net
Thu Feb 25 05:26:03 PST 2016
I noticed that in GDAL >2.0 some utilities and operations support
multi-threaded calculations, such as the gdalwarp utility. I tested it
and it seems to work well. I can see that multiple CPU cores are busy.
Question 1: in gdalwarp there are at least two ways to tell that it
should use more than one CPU:
-multi
and
-wo NUM_THREADS=ALL_CPUS or a nr of cores
Are these two flags redudant? Is either one enough or should I specify
both?
Question 2: can I also speed up the gdaladdo utility?
Thank you for your replies!
Andreas
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160225/0ea113dc/attachment.html>
