[gdal-dev] gdalwarp and gdaladdo in multi-threaded mode
Even Rouault even.rouault at spatialys.com
Fri Feb 26 10:43:08 PST 2016
Le jeudi 25 février 2016 14:26:03, Neumann, Andreas a écrit :
> Hi,
> I noticed that in GDAL >2.0 some utilities and operations support
> multi-threaded calculations, such as the gdalwarp utility. I tested it
> and it seems to work well. I can see that multiple CPU cores are busy.
> Question 1: in gdalwarp there are at least two ways to tell that it
> should use more than one CPU:
> -multi
This parallelizes I/O and CPU operations.
> and
> -wo NUM_THREADS=ALL_CPUS or a nr of cores
This parallelizes CPU operations over several cores.
> Are these two flags redudant? Is either one enough or should I specify
> both?
Both are independant and can be combined.
> Question 2: can I also speed up the gdaladdo utility?
Not as directly as above, but increasing GDAL_CACHEMAX may help for big
rasters.
> Thank you for your replies!
> Andreas
http://www.spatialys.com
