[gdal-dev] SCH support in GDAL
Agram, Piyush S (334D) Piyush.Agram at jpl.nasa.gov
Mon Jan 4 09:48:16 PST 2016
  Currently, there are no raster formats that use this projection method.
These are more likely to be used with GCP's or in metadata. But in the
future, these could be used with raster formats - e.g, JPL's UAVSAR data.
Are there other parts of GDAL where support for the new projection needs
to be included, if assuming, some raster format needed to use it?
Thanks
Piyush
On 1/4/16 3:58 AM, "Even Rouault" <even.rouault at spatialys.com> wrote:
>Le dimanche 03 janvier 2016 00:54:41, Agram, Piyush S (334D) a écrit :
>> Hi,
>>    Spherical Cross-track Height (SCH) coordinate system support was
>>added
>> to PROJ.4 about a couple of months ago. This is widely used for
>>processing
>> radar remote sensing data, particularly for the NASA radar missions. I
>> have tried to include support for this coordinate system in GDAL by
>> defining new OGR SRS parameters.
>> You can find the change log here:
>>https://github.com/piyushrpt/gdal/commit/7e8f3c56367689fd4048063a5d0e2cd1
>>5a
>> 93293b
>Technically looks good to me. Just for our information: are there raster
>formats handled by GDAL that will make use of this projection method ?
>> Example output of gdalsrsinfo look's like this:
>> > gdalsrsinfo "+proj=sch +plat_0=30.3 +plon_0=45.1 +phdg_0=-12.2
>> >+datum=WGS84"
>> PROJ.4 : '+proj=sch +plat_0=30.3 +plon_0=45.1 +phdg_0=-12.2 +h_0=0
>> +datum=WGS84 +units=m +no_defs '
>> OGC WKT :
>> PROJCS["unnamed",
>> 	GEOGCS["WGS 84",
>> 		DATUM["WGS_1984",
>> 			SPHEROID["WGS 84",6378137,298.257223563,
>> 				AUTHORITY["EPSG","7030"]],
>> 			AUTHORITY["EPSG","6326"]],
>> 		PRIMEM["Greenwich",0,
>> 			AUTHORITY["EPSG","8901"]],
>> 		UNIT["degree",0.0174532925199433,
>> 			AUTHORITY["EPSG","9122"]],
>> 		AUTHORITY["EPSG","4326"]],
>> 	PROJECTION["Spherical_Cross_Track_Height"],
>> 	PARAMETER["peg_point_latitude",30.3],
>> 	PARAMETER["peg_point_longitude",45.1],
>> 	PARAMETER["peg_point_heading",-12.2],
>> 	PARAMETER["peg_point_height",0]]
>> This is my first time working with OGR parameters. Any comments/
>> suggestions for improvements are welcome.
>> I hope to issue a pull request once the changes conform with established
>> conventions.
>> Thanks
>> Piyush
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>Spatialys - Geospatial professional services
>http://www.spatialys.com
