[gdal-dev] GDAL and Sentinel2
nguler at jlab.org
nguler at jlab.org
Wed Jan 13 10:39:22 PST 2016
I apologize for stealing the subject line. I only realized after clicking the
send button.
- Nevzat
> Dear GDAL users,
> I am trying to extract some map information from geotiff files. I need to
> access this information to generate an ENVI file header.
> I use
> hDS->GetGeoTransform(adfGeoTransform);
> coo_system_str = hDS->GetGCPProjection();
> to get some information I need. But still missing few things and I don't know
> how to get those. What I get from GetGCPprojection() looks like this:
> PROJCS["unnamed",PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",-69],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAMETER["false_northing",0],UNIT["metre",1,AUTHORITY["EPSG","9001"]]]
> When I open the tif file in ENVI, I see many more information as listed below.
> How can I access this information missing from the above commands,
> specifically looking for the "Coordinate System String" printed below. Also
> why do I get (ROJCS["unnamed",...) while (PROJCS["UTM_Zone_19N",...) is given
> when I open the file with ENVI..?
> I appreciate your help and suggestions.
> ---- Map Info Properties ----
> Type = Projected
> Pixel Tie Point X = 0.5
> Pixel Tie Point Y = 0.5
> Map Tie Point X = 145200.0
> Map Tie Point Y = 2189700.0
> Pixel Size X = 30.0
> Pixel Size Y = 30.0
> Units = Meters
> Rotation = 0.0
> ---- Coordinate System Properties ----
> Projcs = "UTM_Zone_19N"
> Geogcs = "GCS_WGS_1984"
> Datum = "D_WGS_1984"
> Spheroid = "WGS_1984",6378137.0,298.257223563
> Prime Meridian = "Greenwich",0.0
> Unit = "Degree",0.0174532925199433
> Projection = "Transverse_Mercator"
> False Easting = 500000.0
> False Northing = 0.0
> Central Meridian = -69.0
> Scale Factor = 0.9996
> Latitude of Origin = 0.0
> Unit = "Meter",1.0
> PROJCS["UTM_Zone_19N",GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",SPHEROID["WGS_1984",6378137.0,298.257223563]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",500000.0],PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",-69.0],PARAMETER["Scale_Factor",0.9996],PARAMETER["Latitude_Of_Origin",0.0],UNIT["Meter",1.0]]
> ---- Extents Properties ----
> Extent Left = 145185.0
> Extent Top = 2189715.0
> Extent Right = 372315.0
> Extent Bottom = 1967385.0
> Units = Meters
> Best regards,
> - Nevzat
> P.S. Is there any language preference for UNIT["metre"...] ? From ENVI I get
> UNIT["Meter"...]
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Nevzat Guler
Senior Scientist
Spectral Sciences
Phone: 781-273-4770
http://www.spectral.com/index.shtml
http://www.linkedin.com/in/nevzatguler
