[gdal-dev] garbled output from gdaladdo in geopackage
Even Rouault even.rouault at spatialys.com
Thu Jan 14 03:27:06 PST 2016
Le jeudi 14 janvier 2016 12:07:44, Thomas Sevaldrud a écrit :
> Hi,
> I've been using the new GeoPackage raster support in 2.0.1, and have
> noticed some strange output from gdaladdo on certain datasets.
> When producing an overview tile which is on the edge of the dataset, so
> that it is not entirely covered by its child tiles, I get random data in
> the parts of the image which is outside the coverage.
Part of tiles outside the coverage would be supposed to be at value 0 (and if
using PNG tiles with alpha=0)
> I'm not sure how gdaladdo does this, but for standard x2 tile pyramids I
> assume it makes each overview tile by subsampling its four child tiles. In
> this case, not all four child tiles have data and the output in the missing
> areas becomes garbled.
> Is this a known issue?
Not that I'm aware of.
> Any workarounds?
> If necessary, I can provide a test case to reproduce it.
That might indeed be useful. Please file a ticket about that.
Even
http://www.spatialys.com
