[gdal-dev] garbled output from gdaladdo in geopackage
Thomas Sevaldrud thomas at silentwings.no
Thu Jan 14 06:13:36 PST 2016
Ok, I've opened a ticket for it here:
http://trac.osgeo.org/gdal/ticket/6309
- Thomas
On Thu, Jan 14, 2016 at 12:27 PM, Even Rouault <even.rouault at spatialys.com>
wrote:
> Le jeudi 14 janvier 2016 12:07:44, Thomas Sevaldrud a écrit :
> > Hi,
> > I've been using the new GeoPackage raster support in 2.0.1, and have
> > noticed some strange output from gdaladdo on certain datasets.
> > When producing an overview tile which is on the edge of the dataset, so
> > that it is not entirely covered by its child tiles, I get random data in
> > the parts of the image which is outside the coverage.
> Part of tiles outside the coverage would be supposed to be at value 0 (and
> if
> using PNG tiles with alpha=0)
> > I'm not sure how gdaladdo does this, but for standard x2 tile pyramids I
> > assume it makes each overview tile by subsampling its four child tiles.
> In
> > this case, not all four child tiles have data and the output in the
> missing
> > areas becomes garbled.
> > Is this a known issue?
> Not that I'm aware of.
> > Any workarounds?
> > If necessary, I can provide a test case to reproduce it.
> That might indeed be useful. Please file a ticket about that.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160114/4f8768fe/attachment.html>
