[gdal-dev] map info and projections from GeoTIFF file to create ENVI header
Dmitry Baryshnikov bishop.dev at gmail.com
Mon Jan 18 09:38:38 PST 2016
Hi Nevzat,
you need to get spatial reference from GDALDataset (via GetProjectionRef
http://gdal.org/classGDALDataset.html#aa42537e1062ce254d124b29ff3ebe857)
and convert it to OGRSpatialReference.
Than use exportToMICoordSys to get MI CRS string.
http://gdal.org/classOGRSpatialReference.html#a1f2908cd5ca33609844ef0c0ff2186ea
Best regards,
     Dmitry
18.01.2016 20:27, nguler at jlab.org пишет:
> It is solved. Thank you very much Even and Dmitry for your helps. I have
> missed the GDAL_DATA variable and it caused me all that trouble.
> Now I need to get the map info string:
> map info = {UTM, 1, 1, 145185, 2189715, 30, 30, 19, North,WGS-84}
> Using hDS->GetGeoTransform(adfGeoTransform) does not give me all the
> information in the map info string. It only gives me elements [4-7], how to
> get the others?
> Best regards, - Nevzat
>> Yes, Thank you Even, I was missing the GDAL_DATA environmental variable. Now I
>> get the same gdalinfo output. Do I need to set this variable while using the
>> C++ classes you suggested before: GetGeoTransform and GetProjectionRef()..?
>> Because, there also I had the same problem.
>>> Le lundi 18 janvier 2016 17:13:14, nguler at jlab.org a écrit :
>>>> Dmitry and All,
>>>> I just downloaded the set of tiff files from earthexplorer and run gdalinfo
>>>> on it. Please see below. I am missing some fields in the output
>>>> information. It is different from what you got. I don't know what can
>>>> cause this? My gdalinfo.exe is not good? Any idea?
>>> Have a look at the FAQ entries about GDAL_DATA :
>>> https://trac.osgeo.org/gdal/wiki/FAQInstallationAndBuilding#WhatisGDAL_DATAenvironmentvariable
>>>> C:\Cubes\LC80080472013174LGN00.tar>gdalinfo LC80080472013174LGN00_B1.TIF
>>>> Driver: GTiff/GeoTIFF
>>>> Files: LC80080472013174LGN00_B1.TIF
>>>>         .\LC80080472013174LGN00_MTL.txt
>>>> Size is 7571, 7411
>>>> Coordinate System is:
>>>> PROJCS["unnamed",
>>>>      PROJECTION["Transverse_Mercator"],
>>>>      PARAMETER["latitude_of_origin",0],
>>>>      PARAMETER["central_meridian",-69],
>>>>      PARAMETER["scale_factor",0.9996],
>>>>      PARAMETER["false_easting",500000],
>>>>      PARAMETER["false_northing",0],
>>>>      UNIT["metre",1,
>>>>          AUTHORITY["EPSG","9001"]]]
>>>> Origin = (145185.000000000000000,2189715.000000000000000)
>>>> Pixel Size = (30.000000000000000,-30.000000000000000)
>>>> Metadata:
>>>>    AREA_OR_POINT=Point
>>>>    METADATATYPE=ODL
>>>> Image Structure Metadata:
>>>>    INTERLEAVE=BAND
>>>> Corner Coordinates:
>>>> Upper Left  (  145185.000, 2189715.000)
>>>> Lower Left  (  145185.000, 1967385.000)
>>>> Upper Right (  372315.000, 2189715.000)
>>>> Lower Right (  372315.000, 1967385.000)
>>>> Center      (  258750.000, 2078550.000)
>>>> Band 1 Block=7571x1 Type=UInt16, ColorInterp=Gray
>>>> C:\Cubes\LC80080472013174LGN00.tar>gdalinfo --version
>>>> GDAL 2.0.1, released 2015/09/15
>>>>> I have the 2.0.1 version:
>>>>> C:\warmerda\bld\bin>gdalinfo --version
>>>>> I will check the history of the file I have. Maybe it is modified. I will
>>>>> also download the same file from earthexplorer and try my routines on
>>>>> it. Thanks for the suggestions. I appreciate.
>>>>> - Nevzat
>>>>> -----Original Message-----
>>>>> From: Dmitry Baryshnikov [mailto:bishop.dev at gmail.com]
>>>>> Sent: Sunday, January 17, 2016 12:57 PM
>>>>> To: Nevzat Guler <nguler at jlab.org>; gdal-dev at lists.osgeo.org
>>>>> Subject: Re: [gdal-dev] map info and projections from GeoTIFF file to
>>>>> create ENVI header
>>>>> I downloaded this scene from earthexplorer, and everything is fine:
>>>>> $ gdalinfo LC80080472013174LGN00_B1.TIF
>>>>>          ./LC80080472013174LGN00_MTL.txt
>>>>> Size is 7571, 7411
>>>>> PROJCS["WGS 84 / UTM zone 19N",
>>>>>       GEOGCS["WGS 84",
>>>>>           DATUM["WGS_1984",
>>>>>               SPHEROID["WGS 84",6378137,298.257223563,
>>>>>                   AUTHORITY["EPSG","7030"]],
>>>>>               AUTHORITY["EPSG","6326"]],
>>>>>           PRIMEM["Greenwich",0,
>>>>>               AUTHORITY["EPSG","8901"]],
>>>>>           UNIT["degree",0.0174532925199433,
>>>>>               AUTHORITY["EPSG","9122"]],
>>>>>           AUTHORITY["EPSG","4326"]],
>>>>>       UNIT["metre",1,
>>>>>           AUTHORITY["EPSG","9001"]],
>>>>>       AXIS["Easting",EAST],
>>>>>       AXIS["Northing",NORTH],
>>>>>       AUTHORITY["EPSG","32619"]]
>>>>> Metadata:
>>>>>     AREA_OR_POINT=Point
>>>>>     METADATATYPE=ODL
>>>>>     INTERLEAVE=BAND
>>>>> Corner Coordinates:
>>>>> Upper Left  (  145185.000, 2189715.000) ( 72d23' 7.97"W, 19d46'16.43"N)
>>>>> Lower Left  (  145185.000, 1967385.000) ( 72d20'44.51"W, 17d45'55.15"N)
>>>>> Upper Right (  372315.000, 2189715.000) ( 70d13' 8.50"W, 19d47'56.92"N)
>>>>> Lower Right ( 372315.000, 1967385.000) ( 70d12'16.74"W, 17d47'24.74"N)
>>>>> Center      (  258750.000, 2078550.000) ( 71d17'19.50"W, 18d47' 4.68"N)
>>>>> $ gdalinfo --version
>>>>> GDAL 2.1.0dev, released 2015/99/99
>>>>> What is your gdal version? Maybe the Landsat geotiff was modified from
>>>>> some software?
>>>>> Best regards,
>>>>>       Dmitry
>>>>> 17.01.2016 20:15, Nevzat Guler пишет:
>>>>>> Thank you Dmitry,
>>>>>> What is the best way to extract the information we got using
>>>>>> gdalinfo.exe by using GDAL classes, within a C++ code? As I mentioned,
>>>>>> I am using GetGeoTransform and GetProjectionRef() but the results miss
>>>>>> many of the information (specifically the map info elements as I
>>>>>> explained in the previous email).
>>>>>> On another note, I actually get a different output from gdalinfo.exe
>>>>>> using my file (please see the printed result below). I got the geotiff
>>>>>> file from my colleague. When I open the file with ENVI, I get all the
>>>>>> information, including GEOGCS information.
>>>>>> Can it be that my file is just corrupted and that's why I don't get all
>>>>>> the information from GetGeoTransform and GetProjectionRef()? But then
>>>>>> how would ENVI is able to extract this information if it were not in
>>>>>> the file?
>>>>>> Thanks again, - Nevzat
>>>>>> C:\Cubes\Landsat\LC80080472013174LGN00>gdalinfo
>>>>>>          .\LC80080472013174LGN00_MTL.txt Size is 7571, 7411 Coordinate
>>>>>> System is:
>>>>>> PROJCS["unnamed",
>>>>>>       UNIT["metre",1,
>>>>>> Metadata:
>>>>>>     AREA_OR_POINT=Point
>>>>>>     METADATATYPE=ODL
>>>>>>     INTERLEAVE=BAND
>>>>>> Corner Coordinates:
>>>>>> Upper Left  (  145185.000, 2189715.000) Lower Left  (  145185.000,
>>>>>> 1967385.000) Upper Right (  372315.000, 2189715.000) Lower Right (
>>>>>> From: gdal-dev [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of
>>>>>> Dmitry Baryshnikov
>>>>>> Sent: Sunday, January 17, 2016 6:57 AM
>>>>>> To: gdal-dev at lists.osgeo.org
>>>>>> create ENVI header
>>>>>> Hi Nevzat,
>>>>>> The landsat geotiff already have CRS embeded in file
>>>>>> $ gdalinfo LC80150362013097LGN03_B1.TIF
>>>>>> Files: LC80150362013097LGN03_B1.TIF
>>>>>>           ./LC80150362013097LGN03_MTL.txt Size is 7281, 7261 Coordinate
>>>>>> System is:
>>>>>> PROJCS["WGS 84 / UTM zone 17N",
>>>>>>        GEOGCS["WGS 84",
>>>>>>            DATUM["WGS_1984",
>>>>>>        PARAMETER["central_meridian",-81],
>>>>>>        UNIT["metre",1,
>>>>>>        AUTHORITY["EPSG","32617"]]
>>>>>> Origin = (706185.000000000000000,3943515.000000000000000)
>>>>>> Metadata:
>>>>>>      AREA_OR_POINT=Point
>>>>>>      METADATATYPE=ODL
>>>>>>      INTERLEAVE=BAND
>>>>>> Corner Coordinates:
>>>>>> Upper Left  (  706185.000, 3943515.000) ( 78d43'24.74"W, 35d36'50.15"N)
>>>>>> Lower Left  (  706185.000, 3725685.000) ( 78d46'35.65"W, 33d39' 3.82"N)
>>>>>> Upper Right (  924615.000, 3943515.000) ( 76d19' 2.05"W, 35d32'39.74"N)
>>>>>> Lower Right (  924615.000, 3725685.000) ( 76d25'33.46"W, 33d35'10.99"N)
>>>>>> Center      (  815400.000, 3834600.000) ( 77d33'38.95"W, 34d36'17.35"N)
>>>>>> Band 1 Block=7281x1 Type=UInt16, ColorInterp=Gray
>>>>>> And this is right CRS.
>>>>>> Where do you get you geotiff?
>>>>>> Best regards,
>>>>>>        Dmitry
>>>>>> 17.01.2016 03:41, Nevzat Guler пишет:
>>>>>>> Dear experts,
>>>>>>> I am reading LANDSAT GeoTIFF files and combining bands to create and
>>>>>>> ENVI cube.
>>>>>>> I am using GDAL to read the GeoTIFF file, and my own custom cube
>>>>>>> writer to write the ENVI style cube. Transferring the map information
>>>>>>> proved to be a bit convoluted. I seek your help to figure out this.
>>>>>>> My first problem is to access map info from GeoTIFF file. The map
>>>>>>> info
>>>>>>> includes:
>>>>>>> map info = {UTM, 1.000, 1.000, 145185.000, 2189715.000,
>>>>>>> 3.0000000000e+001, 3.0000000000e+001, 19, North, WGS-84,
>>>>>>> units=Meters}
>>>>>>> I am able to get the location (x,y), and pixel size (x,y) from :
>>>>>>> double adfGeoTransform[6];
>>>>>>> srcDS->GetGeoTransform(adfGeoTransform);
>>>>>>> But, I could not find any way to get the other variables in the
>>>>>>> string: UTM, pixel tie points, Unit and DATUM. Is there any way to get
>>>>>>> them?
>>>>>>> Finally, for the Coordinate System String, GDAL gives me:
>>>>>>> PROJCS["unnamed",PROJECTION["Transverse_Mercator"],PARAMETER["latitud
>>>>>>> e
>>>>>>> _of_or
>>>>>>> igin
>>>>>>> ",0],PARAMETER["central_meridian",-69],PARAMETER["scale_factor",0.999
>>>>>>> 6
>>>>>>> ],PARA
>>>>>>> METE
>>>>>>> R["false_easting",500000],PARAMETER["false_northing",0],UNIT["Meter",
>>>>>>> 1
>>>>>>> But I should actually get
>>>>>>> PROJCS["UTM_Zone_19N",GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS
>>>>>>> 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],TOWGS84[0,0,0,0,0
>>>>>>> 0,0],A
>>>>>>> UTHO
>>>>>>> RITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],U
>>>>>>> N
>>>>>>> IT["de
>>>>>>> gree
>>>>>>> ",0.0174532925199433,AUTHORITY["EPSG","9108"]],AUTHORITY["EPSG","4326"
>>>>>>> ]],PRO
>>>>>>> JECT
>>>>>>> ION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETE
>>>>>>> R
>>>>>>> ["cent
>>>>>>> ral_
>>>>>>> meridian",-69],PARAMETER["scale_factor",0.9996],PARAMETER["false_east
>>>>>>> i
>>>>>>> ng",50
>>>>>>> 0000
>>>>>>> ],PARAMETER["false_northing",0],UNIT["Meter",1]]
>>>>>>> GDAL gives me PROJCS, "unnamed". And no GEOGCS information is given.
>>>>>>> I am able to get the coordinate system properties by using the
>>>>>>> following commands but I first need to set few things to use
>>>>>>> exportToWTK.
>>>>>>>>>          OGRSpatialReference oSRS;
>>>>>>>>>          char *pszWKT = NULL;
>>>>>>>>>          oSRS.SetProjCS("UTM_Zone_19N");
>>>>>>>>>          oSRS.SetWellKnownGeogCS("WGS84");
>>>>>>>>>          oSRS.SetUTM(19, TRUE);
>>>>>>>>>          oSRS.exportToWkt(&pszWKT);
>>>>>>>>>          printf("%s\n", pszWKT);
>>>>>>> However, this requires me to set SetProjCS, SetWellKnownGeogCS and
>>>>>>> SetUTM first. I don't know these before I read the file. Is there any
>>>>>>> way to get them from the file so that I don't need prior knowledge to
>>>>>>> create the header. When I pull the GeoTIFF file into ENVI, all these
>>>>>>> information is already there. If this list is only or development
>>>>>>> purposes, please let me know if there is any other email list that
>>>>>>> can give me guidance on this quest.
>>>>>>> I appreciate your help and suggestions.
>>>>>>> Best regards,
>>>>>>> - Nevzat
>>>>>>> _______________________________________________
>>>>>>> gdal-dev mailing list
>>>>>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>>>> Nevzat Guler
>>>> Senior Scientist
>>>> Spectral Sciences
>>>> Phone: 781-273-4770
>>>> http://www.spectral.com/index.shtml
>>>> http://www.linkedin.com/in/nevzatguler
>>> Spatialys - Geospatial professional services
>>> http://www.spatialys.com
>> Nevzat Guler
>> Senior Scientist
>> Spectral Sciences
>> Phone: 781-273-4770
> Nevzat Guler
> Senior Scientist
> Spectral Sciences
> Phone: 781-273-4770
