[gdal-dev] map info and projections from GeoTIFF file to create ENVI header
nguler at jlab.org nguler at jlab.org
Mon Jan 18 13:33:02 PST 2016
Dmitry,
After doing this, I following your suggested steps, I get the string:
Earth Projection 8, 104, "m", -69, 0, 0.9996, 500000, 0
Bit, the map info string I need to use looks like this:
map info = {UTM, 1, 1, 145185, 2189715, 30, 30, 19, North}
I tried other ExportTo functions but none gives me the specific map info
string I want. This is ENVI map info string.
I guess I will just have to stitch it together once I understand what the
second and third elements are used for..
I really appreciated your help.
Best regards, - Nevzat
> Hi Nevzat,
> you need to get spatial reference from GDALDataset (via GetProjectionRef
> http://gdal.org/classGDALDataset.html#aa42537e1062ce254d124b29ff3ebe857)
> and convert it to OGRSpatialReference.
> Than use exportToMICoordSys to get MI CRS string.
> http://gdal.org/classOGRSpatialReference.html#a1f2908cd5ca33609844ef0c0ff2186ea
> Best regards,
>      Dmitry
> 18.01.2016 20:27, nguler at jlab.org пишет:
>> It is solved. Thank you very much Even and Dmitry for your helps. I have
>> missed the GDAL_DATA variable and it caused me all that trouble.
>> Now I need to get the map info string:
>> map info = {UTM, 1, 1, 145185, 2189715, 30, 30, 19, North,WGS-84}
>> Using hDS->GetGeoTransform(adfGeoTransform) does not give me all the
>> information in the map info string. It only gives me elements [4-7], how to
>> get the others?
>>> Yes, Thank you Even, I was missing the GDAL_DATA environmental variable.
>>> Now I
>>> get the same gdalinfo output. Do I need to set this variable while using
>>> the
>>> C++ classes you suggested before: GetGeoTransform and GetProjectionRef()..?
>>> Because, there also I had the same problem.
>>>> Le lundi 18 janvier 2016 17:13:14, nguler at jlab.org a écrit :
>>>>> Dmitry and All,
>>>>> I just downloaded the set of tiff files from earthexplorer and run
>>>>> gdalinfo
>>>>> on it. Please see below. I am missing some fields in the output
>>>>> information. It is different from what you got. I don't know what can
>>>>> cause this? My gdalinfo.exe is not good? Any idea?
>>>> Have a look at the FAQ entries about GDAL_DATA :
>>>> https://trac.osgeo.org/gdal/wiki/FAQInstallationAndBuilding#WhatisGDAL_DATAenvironmentvariable
>>>>> C:\Cubes\LC80080472013174LGN00.tar>gdalinfo LC80080472013174LGN00_B1.TIF
>>>>> Driver: GTiff/GeoTIFF
>>>>> Files: LC80080472013174LGN00_B1.TIF
>>>>>         .\LC80080472013174LGN00_MTL.txt
>>>>> Size is 7571, 7411
>>>>> Coordinate System is:
>>>>> PROJCS["unnamed",
>>>>>      PROJECTION["Transverse_Mercator"],
>>>>>      PARAMETER["latitude_of_origin",0],
>>>>>      PARAMETER["central_meridian",-69],
>>>>>      PARAMETER["scale_factor",0.9996],
>>>>>      PARAMETER["false_easting",500000],
>>>>>      PARAMETER["false_northing",0],
>>>>>      UNIT["metre",1,
>>>>>          AUTHORITY["EPSG","9001"]]]
>>>>> Origin = (145185.000000000000000,2189715.000000000000000)
>>>>> Pixel Size = (30.000000000000000,-30.000000000000000)
>>>>> Metadata:
>>>>>    AREA_OR_POINT=Point
>>>>>    METADATATYPE=ODL
>>>>> Image Structure Metadata:
>>>>>    INTERLEAVE=BAND
>>>>> Corner Coordinates:
>>>>> Upper Left  (  145185.000, 2189715.000)
>>>>> Lower Left  (  145185.000, 1967385.000)
>>>>> Upper Right (  372315.000, 2189715.000)
>>>>> Lower Right (  372315.000, 1967385.000)
>>>>> Center      (  258750.000, 2078550.000)
>>>>> Band 1 Block=7571x1 Type=UInt16, ColorInterp=Gray
>>>>> C:\Cubes\LC80080472013174LGN00.tar>gdalinfo --version
>>>>> GDAL 2.0.1, released 2015/09/15
>>>>>> I have the 2.0.1 version:
>>>>>> C:\warmerda\bld\bin>gdalinfo --version
>>>>>> I will check the history of the file I have. Maybe it is modified. I
>>>>>> will
>>>>>> also download the same file from earthexplorer and try my routines on
>>>>>> it. Thanks for the suggestions. I appreciate.
>>>>>> - Nevzat
>>>>>> -----Original Message-----
>>>>>> From: Dmitry Baryshnikov [mailto:bishop.dev at gmail.com]
>>>>>> Sent: Sunday, January 17, 2016 12:57 PM
>>>>>> To: Nevzat Guler <nguler at jlab.org>; gdal-dev at lists.osgeo.org
>>>>>> Subject: Re: [gdal-dev] map info and projections from GeoTIFF file to
>>>>>> create ENVI header
>>>>>> I downloaded this scene from earthexplorer, and everything is fine:
>>>>>> $ gdalinfo LC80080472013174LGN00_B1.TIF
>>>>>>          ./LC80080472013174LGN00_MTL.txt
>>>>>> Size is 7571, 7411
>>>>>> PROJCS["WGS 84 / UTM zone 19N",
>>>>>>       GEOGCS["WGS 84",
>>>>>>           DATUM["WGS_1984",
>>>>>>               SPHEROID["WGS 84",6378137,298.257223563,
>>>>>>                   AUTHORITY["EPSG","7030"]],
>>>>>>               AUTHORITY["EPSG","6326"]],
>>>>>>           PRIMEM["Greenwich",0,
>>>>>>               AUTHORITY["EPSG","8901"]],
>>>>>>           UNIT["degree",0.0174532925199433,
>>>>>>               AUTHORITY["EPSG","9122"]],
>>>>>>           AUTHORITY["EPSG","4326"]],
>>>>>>       UNIT["metre",1,
>>>>>>           AUTHORITY["EPSG","9001"]],
>>>>>>       AXIS["Easting",EAST],
>>>>>>       AXIS["Northing",NORTH],
>>>>>>       AUTHORITY["EPSG","32619"]]
>>>>>> Metadata:
>>>>>>     AREA_OR_POINT=Point
>>>>>>     METADATATYPE=ODL
>>>>>>     INTERLEAVE=BAND
>>>>>> Corner Coordinates:
>>>>>> Upper Left  (  145185.000, 2189715.000) ( 72d23' 7.97"W, 19d46'16.43"N)
>>>>>> Lower Left  (  145185.000, 1967385.000) ( 72d20'44.51"W, 17d45'55.15"N)
>>>>>> Upper Right (  372315.000, 2189715.000) ( 70d13' 8.50"W, 19d47'56.92"N)
>>>>>> Lower Right ( 372315.000, 1967385.000) ( 70d12'16.74"W, 17d47'24.74"N)
>>>>>> Center      (  258750.000, 2078550.000) ( 71d17'19.50"W, 18d47' 4.68"N)
>>>>>> $ gdalinfo --version
>>>>>> GDAL 2.1.0dev, released 2015/99/99
>>>>>> What is your gdal version? Maybe the Landsat geotiff was modified from
>>>>>> some software?
>>>>>> Best regards,
>>>>>>       Dmitry
>>>>>> 17.01.2016 20:15, Nevzat Guler пишет:
>>>>>>> Thank you Dmitry,
>>>>>>> What is the best way to extract the information we got using
>>>>>>> gdalinfo.exe by using GDAL classes, within a C++ code? As I mentioned,
>>>>>>> I am using GetGeoTransform and GetProjectionRef() but the results miss
>>>>>>> many of the information (specifically the map info elements as I
>>>>>>> explained in the previous email).
>>>>>>> On another note, I actually get a different output from gdalinfo.exe
>>>>>>> using my file (please see the printed result below). I got the geotiff
>>>>>>> file from my colleague. When I open the file with ENVI, I get all the
>>>>>>> information, including GEOGCS information.
>>>>>>> Can it be that my file is just corrupted and that's why I don't get all
>>>>>>> the information from GetGeoTransform and GetProjectionRef()? But then
>>>>>>> how would ENVI is able to extract this information if it were not in
>>>>>>> the file?
>>>>>>> Thanks again, - Nevzat
>>>>>>> C:\Cubes\Landsat\LC80080472013174LGN00>gdalinfo
>>>>>>>          .\LC80080472013174LGN00_MTL.txt Size is 7571, 7411 Coordinate
>>>>>>> System is:
>>>>>>> PROJCS["unnamed",
>>>>>>>       UNIT["metre",1,
>>>>>>> Metadata:
>>>>>>>     AREA_OR_POINT=Point
>>>>>>>     METADATATYPE=ODL
>>>>>>>     INTERLEAVE=BAND
>>>>>>> Corner Coordinates:
>>>>>>> Upper Left  (  145185.000, 2189715.000) Lower Left  (  145185.000,
>>>>>>> 1967385.000) Upper Right (  372315.000, 2189715.000) Lower Right (
>>>>>>> From: gdal-dev [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of
>>>>>>> Dmitry Baryshnikov
>>>>>>> Sent: Sunday, January 17, 2016 6:57 AM
>>>>>>> To: gdal-dev at lists.osgeo.org
>>>>>>> create ENVI header
>>>>>>> Hi Nevzat,
>>>>>>> The landsat geotiff already have CRS embeded in file
>>>>>>> $ gdalinfo LC80150362013097LGN03_B1.TIF
>>>>>>> Files: LC80150362013097LGN03_B1.TIF
>>>>>>>           ./LC80150362013097LGN03_MTL.txt Size is 7281, 7261 Coordinate
>>>>>>> System is:
>>>>>>> PROJCS["WGS 84 / UTM zone 17N",
>>>>>>>        GEOGCS["WGS 84",
>>>>>>>            DATUM["WGS_1984",
>>>>>>>        PARAMETER["central_meridian",-81],
>>>>>>>        UNIT["metre",1,
>>>>>>>        AUTHORITY["EPSG","32617"]]
>>>>>>> Origin = (706185.000000000000000,3943515.000000000000000)
>>>>>>> Metadata:
>>>>>>>      AREA_OR_POINT=Point
>>>>>>>      METADATATYPE=ODL
>>>>>>>      INTERLEAVE=BAND
>>>>>>> Corner Coordinates:
>>>>>>> Upper Left  (  706185.000, 3943515.000) ( 78d43'24.74"W, 35d36'50.15"N)
>>>>>>> Lower Left  (  706185.000, 3725685.000) ( 78d46'35.65"W, 33d39' 3.82"N)
>>>>>>> Upper Right (  924615.000, 3943515.000) ( 76d19' 2.05"W, 35d32'39.74"N)
>>>>>>> Lower Right (  924615.000, 3725685.000) ( 76d25'33.46"W, 33d35'10.99"N)
>>>>>>> Center      (  815400.000, 3834600.000) ( 77d33'38.95"W, 34d36'17.35"N)
>>>>>>> Band 1 Block=7281x1 Type=UInt16, ColorInterp=Gray
>>>>>>> And this is right CRS.
>>>>>>> Where do you get you geotiff?
>>>>>>> Best regards,
>>>>>>>        Dmitry
>>>>>>> 17.01.2016 03:41, Nevzat Guler
>>>>>>> пишет:
>>>>>>>> Dear experts,
>>>>>>>> I am reading LANDSAT GeoTIFF files and combining bands to create and
>>>>>>>> ENVI cube.
>>>>>>>> I am using GDAL to read the GeoTIFF file, and my own custom cube
>>>>>>>> writer to write the ENVI style cube. Transferring the map information
>>>>>>>> proved to be a bit convoluted. I seek your help to figure out this.
>>>>>>>> My first problem is to access map info from GeoTIFF file. The map
>>>>>>>> info
>>>>>>>> includes:
>>>>>>>> map info = {UTM, 1.000, 1.000, 145185.000, 2189715.000,
>>>>>>>> 3.0000000000e+001, 3.0000000000e+001, 19, North, WGS-84,
>>>>>>>> units=Meters}
>>>>>>>> I am able to get the location (x,y), and pixel size (x,y) from :
>>>>>>>> double adfGeoTransform[6];
>>>>>>>> srcDS->GetGeoTransform(adfGeoTransform);
>>>>>>>> But, I could not find any way to get the other variables in the
>>>>>>>> string: UTM, pixel tie points, Unit and DATUM. Is there any way to get
>>>>>>>> them?
>>>>>>>> Finally, for the Coordinate System String, GDAL gives me:
>>>>>>>> PROJCS["unnamed",PROJECTION["Transverse_Mercator"],PARAMETER["latitud
>>>>>>>> e
>>>>>>>> _of_or
>>>>>>>> igin
>>>>>>>> ",0],PARAMETER["central_meridian",-69],PARAMETER["scale_factor",0.999
>>>>>>>> 6
>>>>>>>> ],PARA
>>>>>>>> METE
>>>>>>>> R["false_easting",500000],PARAMETER["false_northing",0],UNIT["Meter",
>>>>>>>> 1
>>>>>>>> But I should actually get
>>>>>>>> PROJCS["UTM_Zone_19N",GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS
>>>>>>>> 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],TOWGS84[0,0,0,0,0
>>>>>>>> 0,0],A
>>>>>>>> UTHO
>>>>>>>> RITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],U
>>>>>>>> N
>>>>>>>> IT["de
>>>>>>>> gree
>>>>>>>> ",0.0174532925199433,AUTHORITY["EPSG","9108"]],AUTHORITY["EPSG","4326"
>>>>>>>> ]],PRO
>>>>>>>> JECT
>>>>>>>> ION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETE
>>>>>>>> R
>>>>>>>> ["cent
>>>>>>>> ral_
>>>>>>>> meridian",-69],PARAMETER["scale_factor",0.9996],PARAMETER["false_east
>>>>>>>> i
>>>>>>>> ng",50
>>>>>>>> 0000
>>>>>>>> ],PARAMETER["false_northing",0],UNIT["Meter",1]]
>>>>>>>> GDAL gives me PROJCS, "unnamed". And no GEOGCS information is given.
>>>>>>>> I am able to get the coordinate system properties by using the
>>>>>>>> following commands but I first need to set few things to use
>>>>>>>> exportToWTK.
>>>>>>>>>>          OGRSpatialReference oSRS;
>>>>>>>>>>          char *pszWKT = NULL;
>>>>>>>>>>          oSRS.SetProjCS("UTM_Zone_19N");
>>>>>>>>>>          oSRS.SetWellKnownGeogCS("WGS84");
>>>>>>>>>>          oSRS.SetUTM(19, TRUE);
>>>>>>>>>>          oSRS.exportToWkt(&pszWKT);
>>>>>>>>>>          printf("%s\n", pszWKT);
>>>>>>>> However, this requires me to set SetProjCS, SetWellKnownGeogCS and
>>>>>>>> SetUTM first. I don't know these before I read the file. Is there any
>>>>>>>> way to get them from the file so that I don't need prior knowledge to
>>>>>>>> create the header. When I pull the GeoTIFF file into ENVI, all these
>>>>>>>> information is already there. If this list is only or development
>>>>>>>> purposes, please let me know if there is any other email list that
>>>>>>>> can give me guidance on this quest.
>>>>>>>> I appreciate your help and suggestions.
>>>>>>>> Best regards,
>>>>>>>> - Nevzat
>>>>>>>> _______________________________________________
>>>>>>>> gdal-dev mailing list
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>>>>> Nevzat Guler
>>>>> Senior Scientist
>>>>> Spectral Sciences
>>>>> Phone: 781-273-4770
>>>>> http://www.spectral.com/index.shtml
>>>>> http://www.linkedin.com/in/nevzatguler
>>>> Spatialys - Geospatial professional services
>>>> http://www.spatialys.com
>>> Nevzat Guler
>>> Senior Scientist
>>> Spectral Sciences
>>> Phone: 781-273-4770
>> Nevzat Guler
>> Senior Scientist
>> Spectral Sciences
>> Phone: 781-273-4770
Nevzat Guler
Senior Scientist
Spectral Sciences
Phone: 781-273-4770
