[gdal-dev] Intersection of two Layers
Ari Jolma ari.jolma at gmail.com
Fri Jan 22 03:58:06 PST 2016
22.01.2016, 13:49, Kai Muehlbauer kirjoitti:
> This is very good news! If I understand correctly, I could use your
> patch and self-compile gdal to have access to the improved
> layer-intersection function via the python bindings. I'll give this a
> try.
Attached is probably a bit better diff.
As I wrote, similar thing should be done for other layer methods.
Yes, you can use this with the trunk version.
> I also created a ticket here: https://trac.osgeo.org/gdal/ticket/6323
> to keep track of this enhancement.
ok
Ari
> Cheers,
> Kai
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Type: text/x-patch
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160122/2ad3cd90/attachment-0001.bin>
