[gdal-dev] Intersection of two Layers
Kai Muehlbauer
kai.muehlbauer at uni-bonn.de
Fri Jan 22 04:19:40 PST 2016
Am 22.01.2016 um 12:58 schrieb Ari Jolma:
> 22.01.2016, 13:49, Kai Muehlbauer kirjoitti:
>> This is very good news! If I understand correctly, I could use your
>> patch and self-compile gdal to have access to the improved
>> layer-intersection function via the python bindings. I'll give this a
>> try.
> Attached is probably a bit better diff.
> As I wrote, similar thing should be done for other layer methods.
> Yes, you can use this with the trunk version.
Thanks Ari, I keep you posted. If I get this running, I'm also available
for testing the other changes.
Cheers,
Kai
