[gdal-dev] Intersection of two Layers
Even Rouault
even.rouault at spatialys.com
Fri Jan 22 04:26:28 PST 2016
Le vendredi 22 janvier 2016 13:19:40, Kai Muehlbauer a écrit :
> Am 22.01.2016 um 12:58 schrieb Ari Jolma:
> > 22.01.2016, 13:49, Kai Muehlbauer kirjoitti:
> >> This is very good news! If I understand correctly, I could use your
> >> patch and self-compile gdal to have access to the improved
> >> layer-intersection function via the python bindings. I'll give this a
> >> try.
> > Attached is probably a bit better diff.
> > As I wrote, similar thing should be done for other layer methods.
> > Yes, you can use this with the trunk version.
> Thanks Ari, I keep you posted. If I get this running, I'm also available
> for testing the other changes.
Kai, just thinking: do you have spatial indices defined, especially on the
method layer ? If not, that would be the first thing to do since for each
geometry in input layer, a spatial filter is set on method layer using the
extent of the input geometry.
> Cheers,
> Kai
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
