[gdal-dev] EPSG:2065 / South-oriented Krovak support (Czech friends thoughts wanted !)
Even Rouault
even.rouault at spatialys.com
Thu Jan 28 09:04:46 PST 2016
I'm having a look at the following all related issues :
https://trac.osgeo.org/postgis/ticket/1940
https://trac.osgeo.org/proj/ticket/185
https://trac.osgeo.org/gdal/ticket/4762
related to EPSG:2065 support, ie "S-JTSK (Ferro) / Krovak". There's an issue
about the datum shift used, but that's an easy one compared to a more serious
one regarding axis order.
The proj.4 krovak method expects the first value of a coordinate pair to be a
easting, and the second value a northing. Whereas original Krovak (EPSG:2065)
is supposed to be southing first, westing second.
https://trac.osgeo.org/gdal/ticket/4762 suggests to add a "+to_meter=-1"
parameter. Which means that the coordinates supplied are first westing, second
southing (instead of "+to_meter=-1", a cleaner equivalent way is to use
"+axis=wsu", meaning westing,southing,up )
But EPSG would mandate southing,westing.
But admitedly, for less exotic coordinate systems with official EPSG axis order
latitude,longitude (EPSG:4326...) or northing,easting (some Finland projected
CRS for example) we have never introduced in GDAL WKT or proj.4 strings the
+axis option, and the application/user does the coordinate switch itself
before passing that to GDAL/proj.
So, does that sound OK that a user providing coordinates advertized to be in
EPSG:2065 does that in westing, southing order ? Or was this something
particular to this user ? (I'd note that the dataset mentionned in the ticket
is a GML resulting from a WFS server, and we all know the axis ordering issues
related to WFS)
What a mess...
(Using EPSG:5221 which is the easting, northing variant avoids those
headaches)
Even
http://www.spatialys.com
