[gdal-dev] EPSG:2065 / South-oriented Krovak support (Czech friends thoughts wanted !)
Daniel Fenton
dmfenton at gmail.com
Fri Jan 29 07:24:00 PST 2016
Even,
I'm not sure if this helps, but in dealing with an issue with WKID 5514,
this WKT workers to properly convert data from WGS84. This was confirmed
against a customer's source data.
PROJCS["S-JTSK_Krovak_East_North",GEOGCS["GCS_S_JTSK",DATUM["Jednotne_Trigonometricke_Site_Katastralni",SPHEROID["Bessel_1841",6377397.155,299.1528128]],TOWGS84[589,76,480,0,0,0,0],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Krovak"],PARAMETER["False_Easting",0],PARAMETER["False_Northing",0],PARAMETER["Pseudo_Standard_Parallel_1",78.5],PARAMETER["Scale_Factor",0.9999],PARAMETER["Azimuth",30.28813975277778],PARAMETER["Longitude_Of_Center",24.83333333333333],PARAMETER["Latitude_Of_Center",49.5],PARAMETER["X_Scale",-1],PARAMETER["Y_Scale",1],PARAMETER["XY_Plane_Rotation",90],UNIT["Meter",1],AUTHORITY["EPSG","102067"]]
Daniel
*Daniel Fenton*
*Software Engineer | Esri R&D*
*https://koopjs.github.io <https://koopjs.github.io>*
On Thu, Jan 28, 2016 at 12:05 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> Hi,
> I'm having a look at the following all related issues :
> https://trac.osgeo.org/postgis/ticket/1940
> https://trac.osgeo.org/proj/ticket/185
> https://trac.osgeo.org/gdal/ticket/4762
> related to EPSG:2065 support, ie "S-JTSK (Ferro) / Krovak". There's an
> issue
> about the datum shift used, but that's an easy one compared to a more
> serious
> one regarding axis order.
> The proj.4 krovak method expects the first value of a coordinate pair to
> be a
> easting, and the second value a northing. Whereas original Krovak
> (EPSG:2065)
> is supposed to be southing first, westing second.
> https://trac.osgeo.org/gdal/ticket/4762 suggests to add a "+to_meter=-1"
> parameter. Which means that the coordinates supplied are first westing,
> second
> southing (instead of "+to_meter=-1", a cleaner equivalent way is to use
> "+axis=wsu", meaning westing,southing,up )
> But EPSG would mandate southing,westing.
> But admitedly, for less exotic coordinate systems with official EPSG axis
> order
> latitude,longitude (EPSG:4326...) or northing,easting (some Finland
> projected
> CRS for example) we have never introduced in GDAL WKT or proj.4 strings the
> +axis option, and the application/user does the coordinate switch itself
> before passing that to GDAL/proj.
> So, does that sound OK that a user providing coordinates advertized to be
> in
> EPSG:2065 does that in westing, southing order ? Or was this something
> particular to this user ? (I'd note that the dataset mentionned in the
> ticket
> is a GML resulting from a WFS server, and we all know the axis ordering
> issues
> related to WFS)
> What a mess...
> (Using EPSG:5221 which is the easting, northing variant avoids those
> headaches)
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160129/016e5293/attachment-0001.html>
