[gdal-dev] Amplitude virtual bands for complex datasets ?
    Even Rouault
    even.rouault at spatialys.com
    Mon Jul  4 01:18:50 PDT 2016
Le lundi 04 juillet 2016 09:30:44, Bugbuster a écrit :
> Hi Antonio,
> as I was mentioning it in my 1st message,I am running under *Windows*.
> I can see that the PIXFUN is indeed recognized thanks to the log messages I
> have added in all functions.
> I have noticed that the pointer *papoSources* is always *null *!
> If you have a clue, I would buy it :-)
I've add a look at the code and noticed on unsafe practice, but I'm not sure
it explains what you observe. In pixelfunctions.c,
GDALRegisterDefaultPixelFunc() is declared with CPL_STDCALL convention, but in
pixfunplugin.c with "extern CPLErr GDALRegisterDefaultPixelFunc()"; (and thus
C convention I guess).
Even
> Sincerly
> Philippe
> http://osgeo-org.1560.x6.nabble.com/gdal-dev-Amplitude-virtual-bands-for-c
> omplex-datasets-tp5273713p5274571.html Sent from the GDAL - Dev mailing
> list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
