[gdal-dev] Amplitude virtual bands for complex datasets ?
    Even Rouault
    even.rouault at spatialys.com
    Mon Jul  4 02:06:20 PDT 2016
> To check if I understood well :
> I will create a driver that will recognize the
> "DERIVED_SUBDATASET:Amplitude:original_datasetname" syntax. This driver
> needs to now if "original_datasetname" is of complex type (to report it
> can open it)
That or we could also possibly accept non-complex types (assume imaginary part
= 0). Antonio's functions handle complex & non-complex AFAICS
> , and will also expose the derived band somehow (can I
> benefit from the CreateDerivedBand API,
If you write it, yes... (it doesn't exist yet if I wasn't clear)
If you follow the VRT pixel function road, that's a matter of building a on-
the-fly VRT dataset.
http://www.gdal.org/gdal_vrttut.html#gdal_vrttut_creation could possibly be
used. But AFAICS setting the pixel function name isn't supported. Could be
done by implementing CPLErr VRTSourcedRasterBand::SetMetadataItem( const char
*pszName, const char *pszValue, const char *pszDomain ), similarly to what
VRTSourcedRasterBand::SetMetadataItem(...) handles for vrt sources.
> and the pixel functions from Antonio ?).
Would make sense to internalize this code (uses X/MIT license)
> Also, "original_datasetname" can be a subdataset itself.
Yes, that shouldn't matter to the driver. It is just a string that it provides
to GDALOpen() (some care must be taken when parsing
DERIVED_SUBDATASET:algname:original_datasetname, since original_datasetname
can have columns too)
> There should also be a mechanism that will report the existing
> DERIVED_SUBDATASETS upon query (this I did not get yet).
Implement in GDALDataset, the following method (from GDALMajorObject)
virtual char **GetMetadata( const char * pszDomain = "" );
char **GDALDataset::GetMetadata( const char * pszDomain = "" )
	if( pszDomain != NULL && EQUAL(pszDomain, "DERIVED_SUBDATASET") )
		// some stuff. Be careful that ownership of returned char** belongs
		// to the dataset object
	else
		return GDALMajorObject::GetMetadata(pszDomain);
As well as :
virtual char **GetMetadataDomainList(); to report DERIVED_SUBDATASET when it
makes sense (contrary to GetMetadata(), ownership of the returned char**
belongs to the caller)
Even
http://www.spatialys.com
