[gdal-dev] SPOT-7 and Worldview 3
    Shawn Gong
    SGONG at mdacorporation.com
    Fri Jul 15 09:46:17 PDT 2016
Thank you Even.
Shawn
________________________________________
Sent: July-15-16 12:02 PM
To: gdal-dev at lists.osgeo.org
Cc: Shawn Gong
Subject: Re: [gdal-dev] SPOT-7 and Worldview 3
Le vendredi 15 juillet 2016 17:29:19, Shawn Gong a écrit :
> Hi all,
> I have downloaded and built gdal 2.1.1
> Ran some tests on SPOT-7 and Worldview 3
> SPOT-7 tiled dimap: the DIM_SPOT7_*.xml file was loaded fine. But the
> georeferencing was wrong.  The xml seems to indicate ITRF2005 (epsg 4896)
> but it has no projection information in gdal.  The individual geotiffs
> didn't seem to agree with the xml either
I've done improvements in the DIMAP driver (for v2 products) in trunk recently
to support tiled datasets. You may want to check that.
> Worldview 3: the TIL file was loaded fine. UTM georeferencing looks good.
> Thanks,
> Shawn
http://www.spatialys.com
