[gdal-dev] JP2 Segfault
Yves Jacolin
yjacolin at free.fr
Fri Jul 22 00:38:28 PDT 2016
Even, Jukka,
Thank both of you.
@Even, I though that I get this kind of issue :) I checked my formats list,
but maybe at the end of the day, my eyes were tired.
@Jukka, I did not use two --config flags at the same time, but this information
is a great confirmation how to manage such multi config flag, definitively useful
for next time.
Thanks again,
Y.
On Thursday, July 21, 2016 21:23:31 Jukka Rahkonen wrote:
> Yves Jacolin <yjacolin <at> free.fr> writes:
> > Hello,
> > I am working on some JP2 data (total 262 Go) . I started creating a vrt
> > file and then "gdal_translate" them.
> > I always have a segfault. I tried to use a GDAL_SKIP config to use another
> > driver but it seems that I can successfully do this:
> > >> Stack trace in bt <<
> > Starting program: /usr/local/bin/gdal_translate --config GDAL_SKIP JP2ECW
> > -- config GDAL_SKIP ECW -a_srs EPSG:2154 -co BIGTIFF=IF_SAFER -co
> > COMPRESS=JPEG - co TILED=YES -co PHOTOMETRIC=YCBCR ORTHO_EXPRESS_2015.vrt
> > ORTHO_EXPRESS_2015.tif
> clip
> > Using --config GDAL_SKIP ECW doesn't change anything.
> > I can't understand two things:
> > * first: why libNCSEcw is used instead of openjpeg200 lib?
> You have used two times the GDAL_SKIP config option
> --config GDAL_SKIP JP2ECW --config GDAL_SKIP ECW
> In https://trac.osgeo.org/gdal/wiki/ConfigOptions#GDAL_SKIP it is documented
> that for skipping several drivers a comma separated list is needed:
> "The value of this option must be a space delimited list of the short name
> of the GDAL drivers to unregister."
> I suppose that with your command only the ECW driver gets skipped and that
> is not for JPEG2000 at all. Using just one option (or a list) as --config
> GDAL_SKIP JP2ECW should help you.
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
