[gdal-dev] Combining multiple rasters using GDAL Warp API
Daniele Romagnoli daniele.romagnoli at geo-solutions.it
Mon Jul 25 08:28:35 PDT 2016
Hi Damian,
I'm probably going off-topic but, did you consider setting up an
intermediate VRT built on top of your sources?
Cheers,
Daniele
On Mon, Jul 25, 2016 at 4:53 PM, Damian Dixon <damian.dixon at gmail.com>
wrote:
> Hi,
> I would like to combine multiple adjacent or overlapping rasters.
> They will all be in the same projection, image format and the output
> projection will be the same as the source data.
> I believe that this is possible using the command line utility gdalwarp as
> it can take multiple source files.
> I am wondering how to do this through the GDAL Warp API as you can only
> specify a single source file:
> psWarpOptions->hSrcDS
> <http://www.gdal.org/structGDALWarpOptions.html#a65f68e1cf7ca641c5d0a93762d0416d5>
> = hSrcDS;
> according to the tutorial.
> Any hints or suggestions on how to pass multiple files to the Warp API
> would be very helpful.
> Thanks
> Damian
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Ing. Daniele Romagnoli
Senior Software Engineer
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:      +39 0584 1660272
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160725/2783b83b/attachment-0001.html>
