[gdal-dev] Combining multiple rasters using GDAL Warp API
Damian Dixon damian.dixon at gmail.com
Mon Jul 25 08:39:31 PDT 2016
Hi Daniele,
VRT looks a possibility. The VRT format tutorial shows how to do this
programatically:
http://www.gdal.org/gdal_vrttut.html#gdal_vrttut_creation
Thanks
Damian
On 25 July 2016 at 16:28, Daniele Romagnoli <
daniele.romagnoli at geo-solutions.it> wrote:
> Hi Damian,
> I'm probably going off-topic but, did you consider setting up an
> intermediate VRT built on top of your sources?
> Cheers,
> Daniele
> On Mon, Jul 25, 2016 at 4:53 PM, Damian Dixon <damian.dixon at gmail.com>
> wrote:
>> Hi,
>> I would like to combine multiple adjacent or overlapping rasters.
>> They will all be in the same projection, image format and the output
>> projection will be the same as the source data.
>> I believe that this is possible using the command line utility gdalwarp
>> as it can take multiple source files.
>> I am wondering how to do this through the GDAL Warp API as you can only
>> specify a single source file:
>> psWarpOptions->hSrcDS
>> <http://www.gdal.org/structGDALWarpOptions.html#a65f68e1cf7ca641c5d0a93762d0416d5>
>> = hSrcDS;
>> according to the tutorial.
>> Any hints or suggestions on how to pass multiple files to the Warp API
>> would be very helpful.
>> Thanks
>> Damian
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Daniele Romagnoli
> Senior Software Engineer
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax:      +39 0584 1660272
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility  for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160725/5e444f33/attachment.html>
