[gdal-dev] PostGIS Out of db VRT containing JPEG2000 GDAL 2.1 OpenJPEG
Even Rouault
even.rouault at spatialys.com
Sat Jun 4 03:38:59 PDT 2016
Le samedi 04 juin 2016 06:16:00, bboughton a écrit :
> Not sure on 'repost' rules so apologies if this is out of place, but I have
> this GDAL/JPEG2000/VRT/POSTGIS problem that I have put up on GIS Stack
> Exchange with no interest. I am unsure if it is a bug, incorrect setup or
> not even possible.
> Essentially my procedure is:
> Build GDAL 2.1 with OpenJPEG
> Build PostGIS with above GDAL build
> Created VRT file with SENTINEL2 Driver / JP2 files.
> Add to POSTGIS as out of db raster
> Try to query and get 'Raster offline error'
> PostGIS query works fine with of of db GeoTiff and a VRT without JP2 files.
> Because of the popularity of GDAL, PostGIS & the Sentinel 2 imagery I
> figured this may be a stack that could be required in the future. For the
> moment I get around it by converting the JP2 files for GeoTiff but at the
> expense of 2x+ the hard disk space.
> Link to SE question:
> http://gis.stackexchange.com/questions/195934/postgis-out-of-db-vrt-contain
> ing-jpeg2000-gdal-2-1-openjpeg
2 things to check that I've in mind:
- check that the VRT works fine. For example with gdal_translate
- check that the JP2OpenJPEG driver is white-listed in PostGIS conf :
http://postgis.net/docs/postgis_gdal_enabled_drivers.html
> Would be happy to pay for the Kakadu driver if it meant sorting out this
> problem but I don't think that is the issue?
There's no fundamental reason why JP2OpenJPEG wouldn't work.
> Thanks,
> Ben
> http://osgeo-org.1560.x6.nabble.com/PostGIS-Out-of-db-VRT-containing-JPEG2
> 000-GDAL-2-1-OpenJPEG-tp5269888.html Sent from the GDAL - Dev mailing list
> archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
